Topic: only allows me to reach low rpm (Read 1469 times) previous topic - next topic
i have tried changing the cap rotor tfi plugs wires an catilatic converters still imy 88 cougar ls with a 5.0 in it only allows me to reach about two grand an then she spitts an spuders an sometimes kills what do i do an theres not ten thousand on the fuel pump an changed the fuel filter any ideas what else
Quote from: comonstone;326241
Is it throwing any codes?
I would do the coil, and check your spark plug gaps and wires. v-8's still run okay if you have the wires clocked one over until you put it under load. I would also pull codes.
