Topic: TO4E installed and having issues (Read 1348 times) previous topic - next topic
Also i have this problem. If get on it the boost slowly climbs to 9 psi and thats it. Even if i change the setting on the MBC i still get 9 psi. I don't know why it is doing that but it is. What can i do to fix it? And the lines are going from the boost side of the turbo to the MBC then to the waste gate.
Got that fox rash again!
-Resident smartass! :ies:
yeah i am. you pull up on it to adjust it. Its made by turbonetics.
yeah ill have to get that in the morning.
no pics yet...
