Topic: Custom Built Headlight Cluster (Read 3640 times) previous topic - next topic
Has anyone built a set of custom headamps?  87 XR7 is what they will be for.
I have been just disgusted lately with the inside of my lights.  They are down to a flat matte grey instead of
I've looked into getting them re-coated in a mirror finish "stuff" but they place wants like 50-60 for EACH light.  thats $300 bones and is a bit much for my pocket book considering the lenses are still going to be less than crystal clear even after being refinished.
My thought was to fabricate my own series of headlamps using the current housing as a frame so the attachment points will be reusable.  As long as the light bulb position is in the same place...they should line up good.
i guess i'm just wondering if anyone has tried something like this.  I have a few spare parts laying around I could try it on and I'm going to take some pics and photoshop what I mean to see how they would look.
Also, i'm considering abandoning the lenses all together and using ONLY the black out lens covers.
ANYONE BUILT THEIR OWN?  or have feed back on my thoughts/plans.  Suggestions?  Ideas?
Look up Cougars 2 Go's car...
i checked out all his threads and posts but didnt find much for pictures.  I will have to shoot him a PM i suppose.
Thanks for the suggestion
no dice...hes not taking PMs and i never found any threads or pics about his ride or lights
He was making lights only for his car,  there weren't a lot of pictures just photo-shopped ideas. If I remember correctly, the lights he has now, he liked but they weren't the greatest, but hell, none of us can see at night with the headlights we have.
I believe you'll find a pic of his car's custom lights in his signature. Think "BMW".
Here's a few from COOL CATS
I had a thread a couple years ago about custom headlights, but all of the pic links are now dead.
http://www.foxtbirdcougarforums.com/showthread.php?t=6889
I might be able to find some of the originals on my hard drive at home.  I had some ideas but never pursued it much past the concept stage.  The most promising lead at the time was to gut Lincoln LS lights and most likely vacuum form a new lens to fit the shape of the car.
Foxless :(
Quote from: thesoldan;325893
thanks...it would be GREAT if you could rustle up the pics.  i'd love ot see them.
I will be doing some photoshop work to visualize myself shortly.
I checked on a place to re-do all six light housings with the vacuum chrome application, (The side markers would be $30.00 each, the signal pieces would be $35.00 and the main head lamps $45.00 each so each 3 piece set would be $110.00.) and that seemed a bit high..but its better than not being safe at night.  10+ years for $220 might  be worth it since I'd really like to completely ditch the stock lenses and just use the GTS lens covers fitted into place.
Quote from: c_bass16
I don't see how that would work, at least not very well.  The stock lenses have a pattern built into them that shapes the light pattern as it shines from the headlights.  If you remove the lens and replace it with a GTS cover which has no light shaping pattern, wouldn't it just allow the light to scatter sooner and, thus, reduce its effectiveness?
-Jim
1987 Cougar LS 5.0
Dayuumm! I REALLLLLLY want cougars2go's headlights.However,they look like alot of work...too  much for me anyway
im gonna have to settle for driving at night with my highbeams on.:D
i've thought about just blacking out the lights and just leaving the main ones clear..thats probably the route i'll take
331 stroker,rebuilt AOD,8.8 rear w/3.73 gears,dual exhaust..wallmart $20 flat back paint job :D
Quote from: jpc647;325882
Actually, they are bright.  I just have to adapt the wiring from the two-light version to the four-light version so the low beams are bright enough.  The high beams are bright but the wiring is messing up the low beam brightness.
I haven't updated my cardomain but here are more pictures:
http://www.cardomain.com/ride/383878
Quote from: c_bass16;325917
Here's what I could dig up.  It's not everything, but it's a decent amount.  Some concepts look a little sillier than others.
Ford Escape Lights, Fiberglass b/w lights and grill
X
Jeep Cherokee Lights with Mustang GT500 Style grill (lacked turn signals - needed to be custom added)
X
Lincoln LS Lights (grill was photoshopped wider, but the lights are actually larger than shown)
X
Foxless :(
Here's the actual LS lights against the Cougar.  I think it looks pretty good from the front.  But the second and third pics show that the angle of the lens just would not work with the car.  The internals of the light would need to be used in a custom formed enclosure.  If you want to pursue this further PM me b/c I think I still have the LS light.
X
X
X
Foxless :(
Good lord man, After is a beautiful car!:bowdown:
Those LS lights look promising. I would like to see what may come of that. Are those seperate H/L beam lights in them?
