Topic: spark plug gap?! (Read 943 times) previous topic - next topic
spark plug gap?!
with the mods listed below in my signature, what should i put my gaping at with my motorcraft spark plugs? i have the set at 35-36ish right now.
spark plug gap?!
I would say about where your at, I don't see any kind of ignition magnifier. Maybe 34 but I doubt you will notice.
You got some plans for that, You did head work right?
I'm not a 2.3 guy, so maybe someone else could answer.
spark plug gap?!
i went with 35-36ish, it feels fine. thanks for your import though. its appreciated
spark plug gap?!
That's a bit wide.  Pull them into .028-032"
EDIT- Well I guess I should say, that if they feel fine, and you're not having any spark blowout under boost, then the bigger the gap you can use the better.
spark plug gap?!
Ford specs .028-.032 for the 2.3T...
Likely after a couple months when the plug tips "round off", you'll start getting a misfire at higher boost levels...
spark plug gap?!
i put them down to .033 today and it likes that better. what should i set them at when i pump boost to 22psi?
