Topic: im so confused....... (Read 836 times) previous topic - next topic
so i cant get my rotor out of my distributor...  like it wont pull up. ive unscrewed the bolts next to it thinking that would make it slide up but now. im looking at the one im replacing it with and it should be catching on anything making at not wanting to come up..
pull harder?
not sure about 2.3 rotors, but the 5.0 rotors only fit on the shaft one way, there's a key, or tang...
ummmm, they should be snug, but not tight enough you can't remove 'em. hopefully a PO didn't use loc-tite on it or some such..:punchballs:
its on my 2.3. ive pulled pretty hard on it. it will wiggle back and forth but it just wont come up.... im scared it i pull too hard so, im going to break something
keep pullin
so agreed to just pull super hard? lol
i pulled super feakin hard! and it worked!!! i still have dents in my fingers from when i was pulling on it like 20 minutes ago...
