Topic: fuel pressure (Read 852 times) previous topic - next topic
fuel pressure
Havent hooked a gauge up to the rail yet (maybe no need) with the engine running (badly) If i push the needle on the test port in, gas comes out but with no pressure......I should be sprayed right?
I have been having all sorts of drivability issues, starting issues, idle problems. I have replaced everything except ign module and the fuel pump.......have i found my problem?:punchballs:
fuel pressure
It could be a weak pump or a clogged up fuel filter.  Does the car run normally at idle without a load on it?
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
fuel pressure
everything wrong with the car did not add up. Pulled the tank and the fuel pump as a py rubber hose running from pump to outlet nipple.......cracked and split. New pump and hose installed. 30 minutes later roasted the tires off this thing! Life lesson #278- Just because your fuel pump runs doesnt mean you are getting the pressure you need.
fuel pressure
It's possible someone used a non-submersible fuel hose.  I just took care of this issue on the turbo Volvo yesterday.
If you used "std" EFI fuel hose, that's wrong too, but may last for a while.  Mine had some general fuel, PCV, EEC, Emission hose on it...it was dead.  I was upgrading the intank pump anyway, but made sure I used the correct Gates submersible fuel hose.  Expensive .
fuel pressure
no this was the original fuel pump setup. Being 25 years old i am glad to have replaced it
