Topic: Light bulb socket...... (Read 1069 times) previous topic - next topic
I need the passenger and driver side light bulb sockets with long pigtails for the front fender cornering lights.If you have them,let me know.Thanks.
If they're the same as a mustang ill cut em outta the 88 notch im parting out and you can have em.
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
I'm unsure if they are the same or not.These are for the cornering lamps mounted low in the front fenders.They may be the same.Hopefully someone will chime in with that info.
Thanks a lot for responding.Hopefully something will work out.Every time I hope to get to the salvage yard,something comes up or it rains.I'm going next week,and I don't care if it's raining HARD.I'll just get really wet.I can't hold out much longer.
They are a two wire socket not a three , they use 1156 style bulbs
 I hope this helps in your quest Vinnie  :D
Yup. All you need is a Ford reverse light socket from any auto parts store.
1979 Ford Fairmont
[/B]
I'll check Autozone tomorrow.Thanks a lot.I'll report what I find.....or don't find.My journey continues........................................
Quote from: 32VFoxBird;323438
I can confirm this... the sockets are standard 1156 style using the same bulb number. Or if you want, you can use the push in type bulbs and sockets using 3056.
I'll check them out after work.
did you find them? I have an extra one for passenger side
