Topic: SO vs HO distributer (Read 878 times) previous topic - next topic
Is the HO distributor different from the SO, or are the wires just in different order?
Thanks,
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
they are just in different order i believe.
They are the same, plug wires route different due to different firing orders...
