Topic: Arm Rests w/map BADLY needed (Read 909 times) previous topic - next topic
Hey guys and gals.  My door armrest broke and fell off on the drivers side.  Please take a look and see i you can help.  I need the driver side the most..., but could use both.
1985 Thunderbird.  Caynon red if possible... if not i can dye.  I am not concerned about the soft removable arm pad.  The hard plastic molded piece is what i need.
Thanks in  advance!
KB
===85BIRD===
:birdsmily:
just repair it like I did take some angle aluminum and pop rivit it on and use the screw it the bottom it holds great. let me know if you want pictures
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Oh yeah I was able to fix my original door panels with simple small hardware store L brackets stratigically placed so they are hidden.
One of my cars had a 2X4 wood screwed into the door to hold everything up.
They make spray on duct tape now too! :rollin:
cool i can fix it again.... but i would still like to find a pair.  Thanks for the replies!!
KB
===85BIRD===
:birdsmily:
