Topic: 88 tc (Read 963 times) previous topic - next topic
88 tc
HI I'm trying to swap a 351W in a 88 turbo coupe the thing worrying me is the cradle and motor mounts:confused:. Do i need to swap cradles to the v8-v6 I have one from a 88 cougar.Can I use a different  cradle from a mustang and use mustang motor mounts?  Do they make drop mounts for thunderbird or cougars I'm trying to keep the stock hood?
Thanks westie
88 tc
The K members are the same for all '86 through '88 Tbird/Cougars.
Just the engine mounts changed to accommodate the different engines.
Mustang k members will fit, with a bit of fine tuning...but, ChuckW makes custom mounts, there's no point in swapping a k member...look in the vendor section for his post if you're interested.
I have a set, they ARE the cat's ass. :D
88 tc
also you could shim the k member to give you more hood clearance. Some of the guys here who did the swap did this. Do a search on 351w swap and you should come up with alot of usable info.
Got that fox rash again!
-Resident smartass! :ies:
88 tc
can I use the four cylnder kmember?
88 tc
Quote from: thewestie;322874
Quote from: ThunderbirdSport302;322718
Ummm.... :punchballs:
Option 1: find a set of (rare) '86-'88 Tbird/Cougar V8 engine mount brackets, and keep your k member
(good)
Option 2: email chuckw and order a set of his type 6 mounts, and bypass the rare brackets altogether, and keep your k member (best)
Chuck's mounts. here, I made it easy for ya ;)
Option 3: swap in a stang k, and still have shiznitty choices for mounts, unless you want to pay big bucks (more than Chuck's, I'd bet) and go through a lot of work, realignment, etc...
(shiznitty, last resort as an option, IMO)
88 tc
Thanks motors out and on the ground hope to get a set of chucks mounts or its plates and a mig God Bless electric liquid metal glue
