Topic: flipped alternator 2.3 (Read 874 times) previous topic - next topic
has anybody fliped the alternator before? where do you flip it to for a 90 degree intake manifold to fit? or do you flip the whole bracket?
Off of a 4 cyl Ranger with the bracket on the passenger side of the engine.This will allow you to use an alt from any Ranger/Explorer/F-150. Grab the pullies and belts while you are at it too.
:burnout:
