Topic: For those who like to fab (Read 2160 times) previous topic - next topic
Anyone who likes to build custom stuff (watchdevil) ;), you might find this interesting.  Not inexpensive but looks like a neat way to do some custom work.
http://www.percyshp.com/HyperFiber.html
Custom Composite Parts
HyperFiber is the revolutionary, time saving, material that allows you to make your own custom composite parts in minutes. No more mixing high odor resins hoping to get exactly the right ratio, trying to get just the right amount of resin on your material, or wasting resin that sets up in the can or drips off on the work surface. HyperFiber has fiber and resin combined with a dry film on each side for the perfect ratio of material and resin EVERY TIME. Simply cut and form HyperFiber in its uncured state to your desired shape inside, out of the sun. Your work time is nearly unlimited! No longer are you working against the clock to try to get everything done before your part sets up. Once you are finished, simply expose the piece to sunlight or a Percy’s UV light source and the HyperFiber will set up in a matter of minutes! With the material used in HyperFiber, you are also able to form it around the most complex curves and angles without having wrinkles or needing to cut the material.
tbirdregistry.com
26480
27373
Sounds useful.
...and there was light!
WOW!!!!!!!!!!!! have you seen the price???????????
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
lol. no.
21 inches by 21 feet for $271.00. That's a lot of material. probably worth it if you do alot of that stuff.
can we say make your own cowl hood out of fiberglass? lol
Got that fox rash again!
-Resident smartass! :ies:
That may be pushing it's limits.LOL.
Quote from: vinnietbird;322360
12" x 21' -- $271
or
12" x 5' for a mere $83  :hick:
Or we could a group buy of the 21' roll and it would only cost $13* for a 12"x12" piece.
Not a bad price for a gauge pod or something small like that.
[SIZE="1"]*Not including tax, shipping, handling, packing, processing, fuel charge, etc. [/SIZE]:D
tbirdregistry.com
26480
27373
