Topic: Ford Racing Low Ratio Gearset for AOD... (Read 1062 times) previous topic - next topic
Hey guys, quick question…I have two AOD’s sitting on my garage floor. One stock, one supposedly built up. I was told that the built one has the Ford Racing low ratio gearset (the gearset with the 2.80 1st gear). I want to rebuild the trans because was installed incorrectly, so the clutches are pretty roasted on the inside. Is there a way to check to see if it’s actually equipped with the low ratio gearset?  Can I yank the gearset out and see if there are any stampings on it or any other identifying marks? Thanks for your help!
