Topic: New clutch question (Read 2275 times) previous topic - next topic
New clutch question
I need a new clutch and through research on the site, ive read that most people run a centerforce, spec or king cobra clutch but all those threads were older though. As of right now im leaning towards centerforce and getting a firewall adjuster. so i was wondering if anybody has any tips or new news on clutches or a different setup i should look at. Any help is appreciated.
New clutch question
or do i even need a firewall adjuster? can i just use the stock cable with nothing else done to it?
New clutch question
IIRC, the biggest bitch about the t5 is the flywheel being so easy wear out.  tom showed me one once, couldnt help but laugh at how tiny they are.
New clutch question
A firewall adjuster won't work withe a stock brake booster on a regular bird or cat. I'm not sure about a TC though. Isn't an 87 TC a hydraulic clutch?
New clutch question
it looks like a spec stage 3+ is what im going with. quick question though, is there anything i need to make it work or can i just put it in and go?
New clutch question
You won't need a firewall adjuster seeing how your 87 TC has a hydraulic clutch in it. Unless someone converted it before you bought it, which is doubtful.
Be careful removing the trans. You do not want to break the spring clips off the clutch fork.
New clutch question
alright, thank you for that tip and help. its appreciated
New clutch question
That's a pretty stiff clutch for what you have. Do you still have hydraulic?
New clutch question
I dunno much about the 2.3T engines but i know the spec 3 can wreak havoc on a 5.0 based engine.  Its kinda like an on/off switch.
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
New clutch question
well i have a stock clutch right now but im also building for the future because im putting a built ported head and a big cam with a 50 trim turbo hopefully all by winter so thats why im getting such a clutch.
New clutch question
Lets try again, do you have a hydraulic clutch or cable?
New clutch question
Quote from: jangus;321693
it sounds like a have a hydraulic clutch
New clutch question
Quote from: Kitz Kat;320867
Correct...and..correct, lol.
Swap in a '93 Mustang Cobra booster to use a firewall cable adjuster, if you end up going to a cable clutch. You'll need a bell from an '86 or older TC, as the the '87 and '88s had hydraulic.
As for the clutch itself..I couldn't tell you. I'd probably not go with a very bad-ass unit until it got to the point that you absolutely need it though..just my 2 cents' worth. :D
New clutch question
where is the brake booster? and how do i know if a clutch as cable or hydraulic? im looking at the clutches on stinger and it doesnt say what it is. so would i be better off getting a spec 2+?
thank you for your info
