Topic: Intake Manifold Gasket Replacement (Read 1810 times) previous topic - next topic
Does anyone have an easy precedure for replacing the intake manifold gasket for an 88 cougar 302?
Thanks,
Lou
Have you ever done anything like this before?You'll need the gasket set (of course),a tube of Permatex,oil and a filter.It's a good time to swap the valve cover gaskets and thermostat while you're at it if they need to be changed,otherwise,leave them alone.I leave the distributor as-is in the engine.The intake will come off without moving it.
There's a lot of little steps.It'll take longer to type it all up than to do the job.
TAKE YOUR TIME AND DO IT RIGHT>>>>>>>>>
-Remove the upper intake (6 bolts...there are two under the top cover plate)
-remove the hoses to the upper intake (be careful with the hoses to the heater core !!!)
-Unplug the harness and all of the connectors and move them up to the cowl out of the way
-Unbolt the fuel rail from the lower after pushing the schrader valve and releasing the fuel pressure (fuel may spray)
-unbolt the fuel rail from the passenger side of the block
-cover the fender with something like an old blanket and gently pull the fuel rail over to the fender
-unbolt whatever bracket supports you may have going to the lower intake (all of mine are long gone)
-unbolt the lower intake making sure you get all of the bolts and an extra nut where the water pipe is bolted down
-pry up on the lower intake and lift it off of the engine....lift the back up first,and pull it up and away from the distributor and set it aside
-clean the head and block surfaces very well and keep a towel or something in the valley of the block to keep  from falling into the block
-Clean the mating surfaces of the lower intake very well and clean off the oily areas.Smooth and dry surfaces are good.
-This part is different for different people...I put a very thin coat of sealant around the water ports on the heads and lower intake before I install the gaskets....some don't.I've never had a leak.Others leave the gaskets dry and also have very good results
-I use a nice thick bead of black sealant on the block front and back instead of the gaskets because I've had the gaskets squeeze out an a couple of occasions.
-Let the sealant set up for a few minutes,then,carefully set the lower intake into place (after removing the towel and  from the lifter valley).
-start the intake bolts by hand and then torque the bolts down in the specified sequence (I'll try to grab that info)
-Once all of the intake bolts are tightened correctly,reverse the process and re-install everything back where it came from.Triple check the vacuum lines.Leaks are very common (vacuum leaks) after an intake swap or gasket change.If you have any cracked or bad hoses,replace them.Don't cheap out.Do it right the first time.
-drain the oil and add new oil and filter.Remember to re-install the drain plugs.
-check the water lever in the radiator
-check again that all clamps and hoses are tight and as they should be,fasteners are all accounted for and installed
-once you're comfortable with everything,start the car and check it out.
If I missed anything,hopefully a fellow member will chime in.I'm swapping gaskets for you at the computer desk.It's a little different than looking at the engine.
Holy ....that took me forever.
Forgot two steps Vinnie
1. Disconnect the battery
2. Drain the coolant.
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
That's true.Although I usually don't drain the coolant.Thanks for the add-on.
when I have done it, I leave all the hoses on the intake and pull them off the radiator and heater core. Generally easier to keep all the parts in one piece and easier to get on the radiator. X2 on the themostat. If you have not done your t-stat, now would be a good time to do so. Its almost easier to pull the lower intake then not to, to do the t-stat.
Also, it may be easier to pull the distributor out at the same time. Just mark the inside with a sharpie, and do the same to the shaft of the dist. I usually just pop the cap off and leave all the spark plug wires still hooked up.
To make dropping the lower intake back on, easier.  I like to find a couple long bolts, cut the heads off and thread them into the head, diagonal- one on each end.
It acts as a guide, to drop it straight down.
Mike
Thank you to all who reply. Great information!
Lou
