Topic: No EEC self test? (Read 1026 times) previous topic - next topic
No EEC self test?
What would cause the EEC to not go into self test mode when the proper jumper wire is inserted between the STI and the signal return?  I have ran this test many times and am sure I am doing it right, but not getting any results.  I have a test light hooked up from the positive battery terminal to the output pin on the test connector.  When the ignition is turned to run, the light lights up for a second (not flashing the fast codes) is off for a second, then comes back on and does not flash.  I checked and the test light does this even when the jumper wire is not in place.  Any suggestions?  Thanks!
No EEC self test?
Are you having a problem or do you just want to check it for possible codes???
Only two I've see that would not output codes had bad EECs, one was a '89 3.8 Bird and the other a '88TC... I don't know exactly what other problems the '89 exhibited, but the TC belched black smoke and was lean on acceleration, also the fans ran continually...
No EEC self test?
No, I am not having any problems (currently...) but the car I got the engine from sat for a good 10+ years and just  wanted to check stuff out.
No EEC self test?
Here is a short vid of what the test light does that I have hooked up to the output pin on the test connector.
