Topic: offset steering rack bushings (Read 2162 times) previous topic - next topic
Will i need the offset rack bushings?I have a 87 XR-7 and i'm going with the stock 87-88 turbo coupe springs and struts.Will they lower it enough to need the offsets or will the regular ones be fine?
                                                    Thanks in advance,
                                                              Joe
Re: offset steering rack bushings
no, and if its a v8 the front will only lower about 3/4". back shouldnt lower at all
Ditto.  I've got the same springs on my car and did not need to offset the steering rack.
-Jim
1987 Cougar LS 5.0
The won't fit anyway so the point is moot.. The 86-88's motor mount tab on the k-member interferes with the rack when attempting to use them.
Thanks guys,thats one less thing i have to worry about.
