Topic: idleing problem (Read 2764 times) previous topic - next topic
idleing problem
im having a idleing problem. it will idle up to about 1500 to 2000 sometimes. iv been trying to get it stright but i dont know what would cause it? if anyone has any tips that would be grate thanks
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
idleing problem
Vacuum lines, throttle position sensor, IAC... Run codes. The computer will tell you for us.
idleing problem
its not a vac line it would do it all the time. i replaced them and i pulled the codes and all i get is an egr and the stuff for the emeition.
:birdsmily:
idleing problem
next time it does it try pulling up on the gas pedal and see if it goes away.
idleing problem
Check your egr.  Make sure its not stuck open.
idleing problem
iv tryed pulling on it and did nothing and i did not know that the egr could have anything to do with it?
:birdsmily:
idleing problem
Pulll the vac line off the top of the egr while the engine is running, see if that makes it go back to normal. If it does, check to make sure that line is fully intact, otherwise prolly time to replace the egr valve. If I know what I'm talking about anyway.
Mine runs pretty normal w/ or w/out it on, but the motor wont function if the line gets blocked, so if your egr valve is sticking or something to that effect, that should tell you.
idleing problem
i pulled the egr off and its not geting stuck.
:birdsmily:
idleing problem
This may sound silly, hae you checked your thermostat? I know not haing one or having one thats stuck open can cause a high idle problem in some cars
idleing problem
when i pulled the motorr out i put a brand new one in
:birdsmily:
idleing problem
What about your TPS and IAC?
idleing problem
it has a new tps. is the iac the same of the bypass on the side of the throtle?
:birdsmily:
idleing problem
Quote from: sarjxxx;320661
I drove for almost 1 year with no thermostat. Well a lack of thermostat would be a better way to put it. Car never got over two bars on the digi dash. Old thermostat was rusted out and was dug out of the lower intake in pieces. The car would just always think its running cold, because it was. I don't see what that would do with high idle?
idleing problem
How were the emissions deleted? How far out is your idle screw? What is the voltage on the TPS? The IAC is right behind the throttle body on the front side of the motor.
To set idle, if your TPS voltage is good through all voltage ranges.
unplug battery for at least 10 minutes. start car, unplug IAC. set screw to desired RPM. If you cannot get it low enough, either the TPS is bad, or you have leaks(I have seen intake gaskets leak, spray carb cleaner or starting fluid to test for leaks.). Plug back in the IAC. If the motor dies, it is more likely then not the IAC.
idleing problem
it dose not idle up high all the time. sometimes it will and sometimes it wont. dose not matter if its cold or hot out or rain or not. just dose it when it wants to. and what dose iac mean?
:birdsmily:
