Topic: Anyone using a fuel cell that could tell me what fuel sender to use? (Read 1325 times) previous topic - next topic
I have a 10 gallon fuel cell and without checking the resistance I ordered a fuel level sender that said it was for a mustang, I figured it would work but now when my tank is full my gauge reads empty and when its empty it reads full... Ive seen one with a rang from 0 empty to 90 full but Im not sure that will work ether because the stock sending unit is 13 empty 160 full.    Can anyone clear this up for me I dont want to waste more money buying the wrong one again.
1987 cougar XR7 347 stroker FRP BOSS block 328rwhp 10.89 1/4mile @126mph ..so far..
2005 F150 5.4 vortec supercharged @15psi water methenol injected 450rwhp 14.0@98mph on 22's
Quote from: TrickFlow347;320165
Sounds like you have the wrong type sender for your gauge.
For an buttstuffog gauge the resistance goes down as the tank fills.
For a digital gauge the resistance goes up as the tank fills.
From the 87 EVTM:
buttstuffoge gauge, 60-86 ohms empty, 8-12 ohms full.
Digital gauge, 9-12 ohms empty, 154-161 ohms full.
I know its the wrong sender, as Ive been reading about it I guess they changed the senders in 1987. My car is an 87 XR7.  I need a sender that reads 13 ohms empty to 160 ohms full and I cant find one.  Any 87 up mustang should use the same one so I would think they have them somewhere.
  Anyone know if I could buy the 0 ohm empty to 90 ohms full and use a resistor to get the reading right??
just reverse the internal wiring and then calibrate it using a resitor on the top or lower end..
There are no wires, its all sodered to a board but I was thinking about tring something like that...same thing as my oil pressure gauge...I was hopeing I wouldnt have to expirament so much.
