Topic: Factory fog lamps (Read 1600 times) previous topic - next topic
Factory fog lamps
I am doing the TC nose on my car. I heard that there is already the connectors in the harness on my sport for the fog lamps? If this is true where do I look for them? One should be by the head light switch for the fog lamp switch. The other is on the drivers side frame rail?
Thanks
:burnout:
Factory fog lamps
My Sport has zero provisions already installed for the fog lamps.Go buy a fog light wiring kit at Autozone or wherever,and hook them up.The kits are cheap and have the switch,relay,and wiring.I was fortunate that my NOS fog lights also came with a Ford wiring harness for them.
Factory fog lamps
. Someone told me it is there. Oh well. I have the factory switch and the harness that goes from the main harness too the fog lights. I want it to look as factory as possable.
I did find the passenger power seat switch harness and pigtail. Now I am searching for a seat track.
:burnout:
Factory fog lamps
I've used a factory fog lamp switch with a new harness and spade clips to plug into the back of the switch.No big deal,and a factory look.I like factroy appearing parts as well.
Factory fog lamps
Hmm, factory with a hood that wont close...
Factory fog lamps
Oh the hood closes now. With room to spare. Spacers. Nobody can see them and it levels the front out a bit but still has a slight rake to it.
:burnout:
Factory fog lamps
Well I guess I will use the factory stuff and get everything hooked up to look factory for the lights. A relay and some wire. Should be good to go. I could hook it into the park light circut for a trigger. Sweet.
:burnout:
