Topic: comp help! (Read 6421 times) previous topic - next topic
comp help!
well i have a laptop i have been building up got everything i think. but when ii try to turn it on it doesn't fire up. now i don't know if i have a processer in it or not. now where would it be located? and just fyi it is a dell latitude xp. thanx for the help everyone.
Got that fox rash again!
-Resident smartass! :ies:
Re: comp help!
not sure about laptops, but the processor should be a large chip with heat-sink on it and a fan. when you turn it on, does nothing happen?
Re: comp help!
yup nothing happens. so i don't know if it has one or not and where it would be located.
Re: comp help!
If I were you I'd do a search on Ebay for the model of laptop you are building. If you luck out you may find somebody selling a motherboard that has a pic of it. If you could see a pic of it and imagine how it would mount in the chassis you should be able to see where the chip would go
Re: comp help!
i shall do that thanx for your help. but if verything is there what would be my prob with it not firing up?
Re: comp help!
Could be a bad power supply, a dead motherboard, a bad battery, or even a bad power switch.
Re: comp help!
thanx ill check it out
Re: comp help!
The CPU on a laptop is generally close to whatever area of the laptop has the most holes in it for ventilation.
I hate servicing laptops. Just dissected one yesterday. Ugh.
Re: comp help!
ok than this one must not have one but i know it needs one to operate. so im back to square one. trying to find it. no vent holes on it at all.
Re: comp help!
No vent holes at all? is it like 10 years old?
You can't run a laptop these days without some sort of air induction. Even that laptop I worked on yesterday was only a 900 MHz. CPU, and it had to have a heat pipe and a fan. My own Athlon 2000+ laptop has about the same ventilation as that 900 MHz. one, but has a bigger heat sink inside.
Hell, I think even my last laptop, which had a 100 MHz. CPU, had ventilation.
Re: comp help!
The cpu on my laptop is located under the keyboard assy.
Re: comp help!
Dells aren't too terribly hard to fix tho the pain is getting the thing open to work  on, after that it's cake. You're gonna have to disconnect the lcd screen and pull the keyboard/keyboard bezel off. One that's done look at the back of the laptop for vent holes, there have to be some, once you find them looked for a hunk o metal screwed to the board, it may be on top, tho i doubt it, so you'll have to unscrew the board from the rest off the case. It should be there. If all else fails and you can do it, take some pics of it and post them. It'll help us help you!
Re: comp help!
i will when i get some time and the cam fixed and whenever i can have the comp free due to everyone here whanting the  thing. sorry just venting my frustrations of living at home. but i will do what i can withe verything elts i have to do.
