Topic: need to change speedo gear (Read 1789 times) previous topic - next topic
I hope someone can give me advice on wich speedo gear I need
running a 8.8 with 3:27 gears and p255/60r15 tires in the rear.
speedometer seems to be around 10 mph off. when the speedometer reads 65 mph it feels more like 55 mph.I am going to verify this with my gps.
If more info is needed,let me know.
wich speedo gear should I be looking for,to get the speedometer back to being somewhat close.
does anyone have the gear I need?
thanks,I just hope I can figure this out............lol.
If you have a 6 tooth tranny gear (inside the tranny),you'll need a 16 tooth speedo gear.
If you have a 7 tooth gear in the tranny,you'll need a 19 tooth speedo gear
An if you have an 8 tooth tranny gear,you'll need a 21 tooth gear.
That's for 3.27 gears.
Here's another handy chart
http://www.latemodelrestoration.com/page/Mustang-Speedometer-Gear-Application-Guide
Each tooth less on the driven gear will increase the reading approx 3-4 mph, so you should need one with three teeth less than what you have now...
thx for the help and the links guys.
Turbo
your statement has me confused (not so hard to do).
I need to decrease what the speedometer is reading.
this may help...
OOPs I was thinking it was slow, guess I wasn't awake yet... You'll need to add teeth...
TurboCoupe50 was wrong!  Is this a first?  ;)
First time I seen it.
TED (seems to be wrong all the time according to my kids)
Quote from: Cad-T-Bird 500;319396
I thought I was wrong once, but I was wrong... :hick:
