Topic: 5.0 engine swap (Read 5031 times) previous topic - next topic
5.0 engine swap
i have an 88 thunderbird turbo coupe and i am swaping a 302 into it.  The problem i am having is that i cant find any motor mounts for a thunderbird or cougar V8. I am trying to locate the plates that bolt to the engine and frame.  does anyone know where i can get some or does any have some i could buy?  Thanks for your help!
Re: 5.0 engine swap
napa for sure..auto zone, cap, anywhere realy should have them available...
~John~
Re: 5.0 engine swap
Assuming you mean the upper bracket that bolts to the block, your only bet is the junkyard. They are a dealer only part that has been discontinued...
Re: 5.0 engine swap
There were some up on ebay,unsure if there still there.
Re: 5.0 engine swap
don't bother with trying to find the bracket that bolts to the engine. just goto autozone and get mounts for a '84-'92 Lincoln Mark VII. they are they same mounts known as "conv mounts"...
Re: 5.0 engine swap
Thanks to every one for all the help. I work at autozone so i am going to check out those mounts for a Mark VII. :flip:
Re: 5.0 engine swap
Quote from: 88TurboBird
But they WILL NOT fit a '86-'88 Tbird/Coug.... Mounts are unique to these years...
Re: 5.0 engine swap
so, how would a feller go about getting mounts then?
would a mustang k-member have to be used, and mounts, or will the k-member even fit?
Re: 5.0 engine swap
you can swap k-members from a mustang to a t-bird but its not real easy and it would cost alot more money to do that.
Re: 5.0 engine swap
mustang k-member bolts right up, no problem. :D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Re: 5.0 engine swap
well, the cost would be worth it, and who said life was easy...?  :hick:
