Topic: tire size delima????? (Read 3877 times) previous topic - next topic
ok, I have 275/50/15 on the car now but they no longer make that size in a street tire, I was thinking of putting on 275/60/15 but I don't know if they would look too big. Does anyone have pictures of my similar year with that size? otherwise I will have to go with a drag radial wich I don't want because it rains a lot in the shunshine state.lol
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
They would about 2" taller.
I want street tires not drag radials
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
What about a 295/50/15?  If you can go the extra width they are still made by BFGoodrich.  It will also make the tire a bit taller (26.7" versus 25.8") but not as tall as the 60 series tire.  If not then it may be time to change to a larger diameter wheel which is most likely not the answer you are looking for.
What is the width of the rim these are going on?
Darren
The overall diameter of a 275/50/15 is 25.83". The overall diameter of a 275/60/15 is 27.99", so you are looking at a difference of 2.16". I don't have any pictures, but hopefully that will give you an idea.
http://www.gripston.com/search?q=275%2F60%2F15
295-50/15
http://www.gripston.com/search?q=295%2F50%2F15
FWIW - I run a 255-60/15 out back.  27 inch tall tire.  Fills the wheel well nicely.
This is the only good pic I have with the new tires.  I'm currently running them on the 10 holes....... I'll be putting them on an 8 inch rim soon....
Quote from: Aerocoupe;318845
Darren
I don't know if those will fit in the wheel well the rims are 8.5 wide
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I hear you on the drag radial, but I can offer a suggestion on a DR which you may find acceptable.
I have run Nitto 555r's for at least 6 years (on my 2nd set).  I have found them to perform very well in the rain and of course when it's dry (I've taken it on three Power Tours).  It is (IMHO) more of "middle of the road" tire, offering considerably more stick than a standard street radial, but with a "real" tread pattern to drive in most weather (you don't have to worry about snow...).  The life of the tires can be as much as 15k miles, but in reality, if you run them in the rain, they are done in 9k-10k miles (fewer burnouts could give them a bit more life).
On a powerfull car, I have found them to offer an additional safety factor when driving a little harder (the back end is less likely to come around on powershifts or when giving it power around a corner).
Keep in mind they have substantally less hook than tires like the M/T DR or the new Nitto NTO5R, but those examples have virtually no tread and are pretty scary in the rain!
I have a set of Nitto's for the street and a set of M/T DR's for the strip.
With the power of your 347, I suspect you may appreciate some traction on the street.
Mark
Yeah, 8.5" is a little on the skinny side for a 295.  I am running a 275/40/17 on a 9" wide wheel.  My buddy ran the 295/50/15's on a 15 X 10 Drag Star and it filled the rear on his 86 GT.  Sounds like the Nitto 555r's are a good compromise and they are available.  Cost may be another issue though.
Anyone else run the Nitto's on a car that sees rain?
Darren
Quote from: 86T-bird;318886
Mark
 hey did you get my pm
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
PM?  Sorry, no I haven't.
Mark
Quote from: 347Thunder;318839
Sorry I did not even notice what they were, I only saw the size.
TED
heres some old pictures of 275/60/15's to get an idea.the first two are on a 15x7 wheel and the last picture is on a 15x10 wheel.
Not to hijack, but what is considered to be "stock" size in the 15"?  According to the load placard, it's a 225/60-15.  I run that now, but find that my speedo is about 2 mph off (reads high).  Car is the LS which originally had 14"s.  I think if I go up one or 2 sizes I'll get the height correction.  But, I don't want to get too "tall" looking.  I have 10-holes which I think are 15x8?  Or is it 7?  I wouldn't mind trying a 50 or 55 series if I could come up with something that'd work...and not rub...
'87 Cougar LS V6 (stock) Daily Driver
'06 Lincoln LS V8
'12 F-150 SCrew FX4 5.0L
'80 Thunderbird V8 (mild 304) [sold to friend]
