Topic: Good Price? (Read 1918 times) previous topic - next topic
Good Price?
Ok so before i drop the engine a must is a good cam... My friend with a 88 stang has his Mass Air conversion and it worked really well, couple years later and it is still working great with these huge cams he has. so my main question is does this kit have everything needed and is there anywhere else i could get it a little cheaper? How much did you guys pay for your conversions? 650 dollars is alot of money and would delay my engine being put in for another couple months probably... i dont like the sound of that. is there any cheaper way....
Here is where i found the kit and stuff.
http://www.mass-air.com/Products.htm
Good Price?
That price is rediculous. You can convert with junkyard parts for way cheaper. The EEC will be the most expensive part.
1979 Ford Fairmont
[/B]
Good Price?
Ok yeah thats the only thing that confused me, that computer, does that mean ill have to change out from the h.o. computer i just bought or what?
Good Price?
Yup
1979 Ford Fairmont
[/B]
Good Price?
if I were you I would do the HO swap , get the car running good  and drive it for a while  THEN think about cam upgrades and mass air conversions
 but that is just me :D
Good Price?
Quote from: hypostang;318778
What Darryl said.
The MAF conversion on the cheap is easy to do if you aren't afraid of a little wiring work  (and no you can't use crimp connectors and expect em to last)
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
Good Price?
You can gather parts as money allows, and do it later on.
Just throwing the mass air on a stock HO will actually be detrimental as you'll lose some off-idle response, etc.
I've got a big-assed cam, and some, but not all of what I need to do the conversion. I still need an A9L eec...which, if you have a T5, would be the best one to get. ;)
Good Price?
lol I wanna try that fun looking column AOD convert to 5 speed thing buuuut it looks as though it could be a PITA so its a long term dream, the MAF i wanted before i put the engine in so i could have cam in as well but i think ill get the money outta the computer i JUST friggen bought and actually use it....gosh a 1990 lincoln EEc-IV wont work with itt? :(
Good Price?
Nope............................. they never made a mass air Mark VII they were all speed density
Good Price?
. Oh well I'm not gunna waste my money I'll use it for a whole :P
Good Price?
EEC - A9L $50 from Corral.net
MAF Pigtail - Free (pocket) from junkyard
EEC Pins and 50" of wire - Free (Pocket) from Junkyard
MAF - 3.8L Taurus $55 from JY.
Injectors - Came with my shortblock, but you should be able to get some from a JY or a mustang friend.
FYI, 88s with the full electronic cluster already have the VSS signal attached to the ECU.
I cut off about 6 inches of the stock air hose.  I ditched one of the rubber bushings from the airbox, and stuffed the maf in between.  Works great, even with my TFS1 cam.  Idles like a bus.
Good Price?
So because my car has the digital dash and stuff, I don't need a vss signal? What us that anyway?
