Topic: LCA cross reference (Read 2429 times) previous topic - next topic
LCA cross reference
I'm looking for LCA bushings for the Cougar and wondered if there was a Mustang that used the same part, just to make ordering easier.
Anyone know what Mustang used the same LCA bushings?
Thanks
LCA cross reference
I hung a set of LCA's on my friends 88 cougar.  They came directly offa my 86 stang GT.  It was a nice easy bolt in.
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
LCA cross reference
If the bolt holes, mounting spacing, and ball joint spacing is the same, it will fit.  That doesn’t mean that the LCA bushings are interchangeable.  And that’s the question I’m looking to answer.
LCA cross reference
Best I can decipher through online catalogs  the stang and cougar are different
LCA cross reference
Quote from: hypostang;317941
That's what I was finding too.
LCA cross reference
Have you called Autozone?I had them find some for me,then I decided to just swap in the SN-95 lower control arms for the front.They were a direct swap,and had GREAT bushings.I had to have the friggin arms off anyway,and while they're off,it's the perfect time for new ball joints.They don't cost much,and they are probably pretty tired anyway if you've never replaced them.
LCA cross reference
I had a :mullet: moment on that one.  I was thinking of rear lower control arms.
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
LCA cross reference
Well,then my answer would be as follows.......when I was looking to swap bushings, Autozone stated that they cod get them in factory style or through Energy Suspension.
LCA cross reference
87-88 TBirds/Cougars use different LCA bushings than the Mustangs and the 83-86 Tbirds.
LCA cross reference
I have the lower control arms from my car,and I believe the bushings are still in good shape.
LCA cross reference
Quote from: Chuck W;317968
Thanks for the confirmation
LCA cross reference
Quote from: xjeffs;317926
Thanks
Wanting factory parts, or something performance-oriented?
"relevant post"
LCA cross reference
Yeah I ordered from Energy Suspension Parts and they were on back order.  I was trying to cross reference though Max Motorsports.  Wouldn't mind a little tighter, not hard as a rock though.  I'm keeping the 15's so that should soften it up a little.
LCA cross reference
Really? I ordered mine through an AutoZone, got em in about 4 days...I did order some spring isolators directly from ES, no waiting for them..
Did you get the black ones? (that may be the difference maker...mine are all red)
