Topic: UPR 1994-2004 mustang billet gas lid (Read 4301 times) previous topic - next topic
So I paid $30. for it so let me have it, I like the look but I think it is a little small for the opening. What do you guys think?
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
looks good and the fit looks correct.
It is slightly small but I think it looks great , much better than the stock lid
I actually like that better than mine.I think the slightly smaller circumference makes it "fit" better.I like the black as well.
Quote from: vinnietbird;317249
Hey vinnie can you direct me to pictures of yours I can't seem to find them
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I had mine painted to match the car.When it was on my blue Thunderbird,it looked like a big silver spot on the side and looked wrong to me,so,the paint......
any closer
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
How about this....
I'm gettin a black one !!!!:D
did you space it out from the car to make it flush?
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Kind of.I used some black rubber gasket material and I carefully made a nice round factory appearing gasket to place it between the lid and the body.I didn't want metal to metal. It was about the thickness of a quarter.
Quote from: hypostang;317272
this is the one I got.
http://www.uprproducts.com/mustang-billet-fuel-door-flat-black-94.html
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Quote from: vinnietbird;317274
very nice going to do that now, if you have some time could you measure your lid and the opening I wonder if mine is bigger.:shakeass:
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
The gas lid area on your car is the same as mine.My lid is bigger.
