Topic: gillis boost vavle (Read 894 times) previous topic - next topic
gillis boost vavle
Can somebody give me info  on  adding more boost for stock 2.3 t-5 1986 cougar xr-7 can I  change the valve without making other  changers. Info on best boost kit- whats stock psi and on a gillis upgrade
gillis boost vavle
any MBC will work, with the 86 you should have a T3 turbo, it is maxed at about 20 psi
clip the hoses off at the BCS solnoid, but leave the wires hooked up
now at the comprossor side of the turbo, you have a fitting with 2 hoses, one went to the BCS the other runs to the WGA, either block one nipple or remove and replace with a single nipple fitting (its a 1/8 npt fitting) run the hose from the compessor to the bottom of the MBC and then a new hose to the WGA.
the next cheap and (semi) easy mod will be to gut the upper intake, a sawsall will be needed ( a fire/rescue blade seems to work best) and cut the bannanna out
when you have the upper intake off you will see this...
after you make the 4 cuts, you can smooth the sharp edges and/or port the rest of the fins out. so you end up with something like this...
trim the gasket to fit the upper and clean all the metal flake out of the upper.
also if you have the time, knife edge the lower intake and gasket match
also grab up a ranger roller cam and follower set, this is a cheap cam upgrade, and been proven over the years to support appox 300hp
gillis boost vavle
i have a question... what does enlarging the holes on the intake side do for boost? does it increce or decrece?
Got that fox rash again!
-Resident smartass! :ies:
gillis boost vavle
Dont turn your boost up too much without an intercooler.
gillis boost vavle
the intake mod will allow you to pack moore air to be ready when the valve opens, it will nod increase or decrease the boost, just allow you to have more compressed air ready to enter the engine
the intakes are the same for na or turbo
