Topic: Trip Minder info needed.... (Read 1521 times) previous topic - next topic
I installed the trip minder....I have NO idea how to use it.I need instructions and any info you guys have for it. What each function is,and what I need to know.
My car is still in the shop, so I'm pulling this from memory.
To set anything, first press "set" then press what you want to set. For example, to set the clock, press "set" then press "time".
To reset anything, first press "reset" then press what you want to reset. So to reset the gallons used, for example, press "reset" then press "fuel" when it's showing the gallons used display.
The buttons at the bottom tend to have multiple displays. Pressing any of them will toggle through them.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
I'll give it a try.Thanks a lot.I may mess with it during my 30 minute lunch break tomorrow.
For you Vinnie!
Tripminder from my 84 owners manual...
Last two pages...
i think this should be a stickey for others to turn to when they install one in there car.
Got that fox rash again!
-Resident smartass! :ies:
Quote from: Cougar8775;317075
I agree.
Watchdevil....thanks for posting the instructions.I appreciate that. I'll set it all up after work and report on it.That's a lot of stuff for such a small little box.LOL. I'll also try to find my owner's manual as a back up.Thanks again.
Very nice, thank you for doing that Watchdevil.
Mike
I agree that this should be sticky somewhere.  Thanks for posting!
Yup, it's a really innovative piece of equipment, especially for 1984. It's also really useful with our notoriously inaccurate buttstuffog gas gauges.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Mines notoriously optimistic... I usually put at least two gallons more in than what it says I used.
