Topic: Need some help (Read 2294 times) previous topic - next topic
Need some help
I was driving home today like usual, got off my exit let off the gas and started to coast to the light went to hit the gas to get a bit farther and the gas pedal went down with ease no real resistance. I knew something was not right but I wasnt home so I had to continue the car also didnt seem to be shifting correctly either.
Got hom popped the hood and this is what I saw
It seems like the bottom wire isnt coming all the way back to where it should. It runs down under the car to the tranny??
Is it going to screw somehting up by driving it like this. It is my ride to work in the morning??
Thanks guys
:ford::oldcougar::mercury:
Need some help
That looks liek the TV cable.You'd better have it checked.Tranny work can be expensive.
Need some help
That does look to be the TV cable, which is bad.
Need some help
I'm not driving it I took the truck to work.. Fixable? Or not worth it just replace? I haven't gotten under it yet it was late and getting dark as yiu can see by py picture.
Need some help
Without the TV cable your overdrive band will burn out with in a matter of a few miles
87 TC
Need some help
Quote from: bigbada1;316821
Confirmed.  See my post about replacing it. Mine slipped off while my dad was transporting my SC.  OD was pretty much gone by the time he realized it and fixed it.
Need some help
I had that happen twice.......that's why I have a 5 speed now,.
Need some help
Brass bushing+clip=no TV cable falling out ;)
Need some help
Quote from: vinnietbird;316854
I would loove to swap the 5 speed into it but its a V6 is it possible? If so when you coming to help install?? LoL I could use the expertise im sure you have..
Quote from: thunderjet302;316862
It didnt slip off ( well not to my knowledge the tops still on) Im hoping its as easy as just putting the bottom back on and done no damage at all but im usually not that lucky :punchballs:.
Need some help
its easy to convert a v6 to 5 speed. just get a mustang v6 5 speed donor car thats the easy way or just piece it together from different mustangs.
Need some help
I have a V6 T5 bellhousing and separator plate I would like to get rid of. :evilgrin:
Need some help
Not to derail the thread but are you all talking about switching the transmission to 5speed automatic?
Need some help
Well I still have gotten nowhere with it, I havent got under it to check yet...
Josh I am talking abot switching it to 5 speed manual.
Need some help
Even with the 3.8,a 5 speed would change the whole feel of the car.It would probably make you really happy.
Need some help
Quote from: vinnietbird;317176
That it definitately but would not know even where to start... Youve dont it any idea or are you planning on being in the upstate Ny area anytime soon.. LOL:burnout:
