Topic: Desprate for F150 Fuel lines (Read 747 times) previous topic - next topic
Well I went to the local pick and pull and was able to find a fuel rail but someone had allready cut the flexable line going from the hard lines to the rail any help or is there anywhere I could just by a few feet of new hose and reuse my TC connectors just put in new flexable line?
87 TC
get what you can as far as the rail.  the fuel lines can be repaired fairly easily.  did the just cut it?  is all of the line there?
Ya they cut it almost in half I was just wondering if there was someone who would sell the line I thought that I read you could buy the flexable hose, cut the old hose off of the barb and be able to put new line in by putting the new line with the old barb in boling water
87 TC
if you can get a section of the black plastic fuel line from a junk car it would work perfectly as far as the reinstalling the barbs you can use a heat gun or a lighter with care.
OK That is what I thought and I was wondering if anyone sold the same type of hose or is my only option a chunk from a junk car
87 TC
Is the Dorman 5/16 nylon fuel line that I can get at advanced or Oreilly's the same thing?
87 TC
I've never personally used it, give them a call and see what they can tell you about it
