Topic: ! I found rust ! (Read 1767 times) previous topic - next topic
! I found rust !
Finally warmed up enough that I thought I'd play around in the garage. I was looking around the car, daydreamin' different colors and stripes etc. Looked thru the grill opening, the  bottom of the core support looks like it came from the bottom of a lake !!!
Crusty flakes and holes ! No rust anywhere else, just the core support ! :punchballs:
There's a couple of them in the local Pull-A-Part, is this an easy removal / install ?
88 Sport ,306 roller block, flat tops, ARP rods and bolts, Compcam 533 lift/ 270 duration, roller rockers, ported 351w heads with 1.94 - 1.60 valves, 550 springs, 600cfm carb , full length headers, 2.5" dual X-pipe exhaust, MSD ignition, Hughes built C4, Weld Draglites, Tracloc /Richmond 3:73's
! I found rust !
You'll need a tack weld removal bit.I've seen a few swapped by the Northern guys.We don't have those issues here.
! I found rust !
It's weird, the sides of the support are great. It's just the very bottom of it. I may just scavenge that section and weld it in.
! I found rust !
of course you know I replaced most of the front end.
you need to replace one of these?
! I found rust !
daminc, that's exactly the area of mine that is bad.
I'm debating whether or not to let it go till winter rolls around again.
! I found rust !
if it's still in 1 piece and not flapping, you should have no problem with waiting until winter. This was mine and it was still supporting
! I found rust !
If I'd clean up the flaking it would probably look like your old one. Is the core support the same in the Mustangs or is it T-Bird specific ?
! I found rust !
I believe they're diff, but not sure about just replacing only the bottom. that part may be usable. (unless they're narrower)
! I found rust !
Another place to watch out for...seems somewhat common at least on northeast cars.
tbirdregistry.com
26480
27373
! I found rust !
yes,, they do rust a bit in that area.
