Topic: Toyota's New Recall Fix... (Read 8300 times) previous topic - next topic
Oh, ok. I was a bit confused there. :P And even reading about these DBW systems when they first started becoming common about five years back, it didn't sit well in my gut. The thing I don't understand is why they needed to ditch the cable throttles. These new systems can't be cheaper, and they're  near infallible when you're working with a spring and a cable. KISS!
Quote from: oldraven;314717
LOL
They are no doubt cheaper... The computer controls the throttle body, in cruse just like when you are accelerating... Cruse servo, cabling, vac lines etc are history, one little motor on the throttle body is surely cheaper... Also can't over rev the engine, with tranny in neutral max revs are around 4000-4500 rpms...
For grins I put my '07 Grand Marquis in neutral at around 35 mph and floored the pedal, 4500 rpms max... If same is true for the 'Yotas, placing one in neutral when it's running away will not blow the engine...
Does your Grand Marquis have drive by wire? I thought they were still cable controlled.
I bumped the selector into N once while driving my grandma's '05 Ford 500 on a winter day, not warmed up yet, and I eased down the pedal expecting to go..and it actually limited itself for the cold too apparently, it wouldn't go above 2500 rpm!
