Topic: T5 Scrach in 2nd Gear (Read 1253 times) previous topic - next topic
5.0HO with HCI and exhaust, WC T5 from 89 Mustang GT swapped in.
If I do a High(er) RPM shift from 1st-2nd, I get a little grind before going in.  I know its probably the synchro but I don't have the time to get to it right now.  Lower RPM shifts (<3k) are nice and smooth.
I am running Dex/Merc ATF in the trans.  I was wondering if switching to a full synthetic might improve the shift.
With my Cam and Intake, the car makes great power from about 3500 on up, but I cant shift in those ranges...so i'm sad.  There is alot of ideas on what to run on A WC T5, most of it seems to be voodoo.
Also, I get a grind going into reverse unless I shift into 5th then down into reverse.
Any ideas?
The only thing I can comment on is the reverse thing ,
 the reverse shaft spins backward so they almost always grind ,
 even when new or freshly rebuilt .
When I worked at the Ford dealer we always used the pattern....... clutch in 2nd, 4th , reverse Never had a problem then .
 It actually became second nature after a while .
Yea, I heard that the reverse grind thing was a "get use to it because all Mustang T5s do"  I'm ok with it.  Just thought might tingle someones trouble shooter bone.
Ive always done 5th then Reverse, always worked well.
Mike
