Topic: Why does my shifter sound like a vacuum leak? (Read 1314 times) previous topic - next topic
Forgive me, all my Fords have been 5 spds until this Tbird. My car sounds like it has a vacuum leak as I shift from Park to drive, etc. The tone changes in each gear, loudest in D, well, OD. If I jiggle it just right back and forth a little, the hissing sound stops.
87 Thunderbird LX
65mm tb, exploder intake, iron gt40 heads, 1.6 rr, a9l mass air swap, 9.5" Billet Dirty Dog TC, Built AOD, 4.10's, 31 spline TLoc, Superior Axles, full sn95 five lug swap.
It's more than likely the horseshoe on the steering column that releases the parking brake when you go from park to drive.  Look under the hood at the vacuum tree on the top right side and disconnect "B/R" (the one in the middle) and cap it off..
If it's a column shifter that's your problem.
Thanks!
87 Thunderbird LX
yeah mine does the same but i never really cared.... will it hurt if i just leave it alone? it only hisses in park.
Quote from: Whiteboy;313887
If it is hissing it is leaking, cap it off.
The car will run better without vacuum leaks
Yeah I wasn't paying attention u guys were talkin about the vacuum tree. I'm getting another already lol
