Topic: digital dash (Read 2451 times) previous topic - next topic
digital dash
On my 88 sport, I was putting in a stock radio and heard pffft.  Next thing i know the right side of the display is out....from the sppedo to the right.  the backlight works but the LED's are inop.  I changed a blown fuse and the right side with the digital gauges are good.  Is it a bulb or did I burn up the cluster?
digital dash
so you have a lime light only,, no digit display?
if so,, the manual is pretty intense in trouble shooting this but id gander from a guess that yes you are right, the speedo is hosed.
snap a pic of key on engine off
digital dash
I have a similar problem. I was messing around behind the radio trying to see how to fix a sound problem and heard the same noise, however I have all my digital working the thing that is no longer working is the dash display when I turn on the headlights, One goes one and the other goes off, how weird is that. Any ideas what I could do to fix this?
86" Cougar 5.0 V8
digital dash
Jcassity, here is a pic.  I replaced the blown fuse and the tach/gauges came back..it's the other stuff that is AFU.
digital dash
problem solved. A second fuse was blown.  It is the one with with the door chime and interior lights.
digital dash
hum all my fuses are good, not sure what is causing mine to not work when the headlights are on.
86" Cougar 5.0 V8
digital dash
Quote from: PJsKitty;314318
With the headlights off, the instrument lights are on full bright.
With the headlights on the lights are controlled by the dimmer control on the headlight switch.
digital dash
In that picture, the far right display of my dash doesnt light up, like if the sun or another light hits it right i cant see what it says but there is no lighting. also my cruise control doesnt work, thought it might have to do with that too.
digital dash
Oh mercy me, Ive been on here for this long with little help and now i see I am not alone. I havent logged on to check this place in forever but after the nice weather yesterday i had the urge to start up the Cat. Ive been plagued with the same issues, at first erratic speedo now none. And at first no tripminder, I remedied that by cleaning the contacts on the r.h. side of the gauge cluster.
As for the dashlights not working with the headlights, I had the same issue as well as a problem in the wiper circut. Mind you folks this started with a buzz in my speakers and a faulty heater core.
I discovered grounding the cigarette lighter fixed the backlight/headlight/wiper issue.
After that my 2month out of warranty alternator kicked the bucket.
I replaced it with little issue until the wiring harness going into the alternator melted down right at the plug.
These cars seem to be a wiring disaster, I am personally ready to gut the whole thing and cough up the 700 for a painless kit.
....no speedo, no cruise, door chime is erratic. something went screwy in my column as well is my worst fear. Key still turns power on but solenoid signal wire doesnt work.
sorry for the poor format/rant , i need to sleep on this again.
Current-
87 Cougar
88 Crown Vic LTD
84 Yamaha Xt600
previous cars -
1990 Dodge Daytona -
1990 Geo Prizm -
1987 Honda Accord - 140mph wonder? Rally ready..... K.I.A. at WOT due to massive head failure. Still had the best paint-job EVER...
1998 Suzuki Sidekick 4D -
1969 Falcon Futura w/ Sports Coupe option (now go try and find that? And if you do tell me where it is!!)
The Cougar will never be for sale, Only up for trade on a 68,69 Falcon 2D.
digital dash
Quote from: 87crzypssy;315148
belive it or not, but the mojority of your problems (excluding the alt) could be a bad ignition switch.
FORD The Pacemaker of a CHEVY
digital dash
your dimer stwich might be going bad. i lose all dime lights when mine messes up. i just roll the nob and it works again
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
digital dash
edits below
ok,, just the facts please,, i search for all threads posted by you and i see none in electrical tech stated by you.  It says you have gotten little help but i dont see you asking.
again, facts.  Cant seem to understand why you would say this unless your expecting wires to talk and tell  you where they are jacked up.
sounds like  healthy list, it would be better if you had threads started about these.
