Topic: Are all 83-88 buttstuffog clusters the same? (Read 1030 times) previous topic - next topic
I need an buttstuffog cluster for my int. project and theres an 85 bird at the JY w/a buttstuffog cluster but idk if it will fit with the 88 dash (I dont care about the wiring).
Son of Jleews6, Johnny 5:p
85 GT 1C vert = resto project grey int. no power options but A/C. http://vb.foureyedpride.com/showthread.php?t=92213&highlight=convertible+build+thread
85 GT 2R hatch = ALL original sunroof car grey int.,full scale restoration coming one day
85 GT 2A hatch =  tan int. 2.5" full exhaust, BBK headers, AutoMeter Pro Comp gauges, 5-Lug w/17" Bullitts, converted to FI, 8.8 w/3.55s etc.
90 LX EL hatch = grey int. stock 5.0 auto
85 GT 1C hatch = parts car :(
1983-84 were different (smaller size, cable driven).
The 1985-88 clusters interchange but rewiring will need done.
Ok I may get that. I'm using an 86 GT harness anyways thats why I didnt care about the wiring.
Wait wait wait wait werent the buttstuffog cluster from the 85-88 clusters cable driven too. If not can I swap an 83-84 speedo in a 85-88 cluster or are the gauges smaller (The way you say it makes me think that just the housing is smaller).
The T-Bird/Cougar speedos from 1985-88 were all electronically driven. Only the 1983-84 speedos were cable driven.
I don't believe a 1983-84 cluster will fit in a 1985-88 dash. They're a different size and aren't very usable anyway.
You could swap over the VSS assembly and do a little rewiring, and ditch the Mustang cable setup, in order to make the 1985-88 cluster work in the Mustang. It's been done before.
Quote from: EricCoolCats;312327
The VSS assembly meaning the unit on the trans instead of the gear? Do you think it would be very hard? I'm good with wiring I just dont want to get over my head with this. If I was to ditch the cable setup I think i'd use digital gauges though but who knows I change my mind a lot lol.
I aborted an idea to use a 85-88 Tbird dash in my 84 Tbird. I was going to keep it simple and use the 84 buttstuffog cluster. The cluster itself will fit in the space that the 85-88 cluster uses, but it would have required tpuppies the instrument panel trim at the top of the window box for the gauge opening and fabricating a little bit trim to finish off around the gauge cluster. I had also gotten the 85-88 instrument cluster to use later when I could work on wiring up the speedo to work with VSS instead of a cable.
The whole game has changed since I went with the SN95 Mustang dash. Most everyone knows by now I ended up using an electronic digital cluster from a 1980 Tbird which also slipped easily into the Mustang cluster opening. It has a mechanical cable with a speed sensor built into the back of the odometer.
I have been entertaining the possibility of using an SN95 Mustang cluster at some point but I don't feel like tackling this right now.
let me know how it turns out I can use all the info I can on that.
