Topic: How do I advance the timing on an '87 3.8? (Read 1648 times) previous topic - next topic
My current timing is at 0 degrees and needs to be at 10 for CA emissions. How do I advance it? Do I do it mechanically or with the vacuum advance? Whats the difference?
With a timing light. Do it right the first time. Don't guess at it.
BTW, that's a unique user name...
I know youd use a timing light to advance it mechanically, but Im asking if there is a special procedure for doing it on the V6 Cougar. Do I just rotate the distributor cap and call it a day or is there something more involved?
There is no vacuum advance. Spark advance is controlled by the ECU.
Unplug the SPOUT (Spark Out) jumper and set the timing by rotating the distributor.(not just the cap.)
The SPOUT jumper is in the yellow wire to the TFI module.
^what the master said but unplug it before starting.  plug it back in after shutting down.
i dont know why but thunderchicken made a big deal about it and i just took his word for it a long time ago,, never forgot it.
Thanks softtouch, thats a big help.
I cant seem to find the ECU. Is there a diagram on the site that can point it out for me? Is it in the engine bay or under the dash?
going from adjusting the timing to the EEC?
what happened.
yes, an entire evtm is available for you if you like.
look in electrical tech and go to the thread 2othannivLS posted about his IVR problem.
its in there, the link will take you to photobucket.
Slow your roll there, and stay away from that EEC! You need to know where the TFI is.
i didnt use a timing light and worked out fine, youll be fine too.
wouldnt know how to use one actually :P
the ecu is in the passenger footwell by the door.
what exactly does that have to do with moving the distributor?
Where is the TFI then?
mounted right on the distributor here is a pic for ya
Thanks hypostang, you're awesome! Anybody know what happens if I advance the timing without disconnecting the SPOUT?
I honestly dont know I never tried it
You want to adjust the "base" timing, with the spout disconnected. When the spout is connected, the EEC has control of the timing.
If you adjust it with the spout connected, it will be way off.
CoogarXR : 1985 Cougar XR-7
