Topic: valve cover bolts? (Read 1336 times) previous topic - next topic
valve cover bolts?
I replaced valve covers a while ago, and I tightens a bolt up a little to tight and the head broke off, and now it's stuck in there. Anyone have any idea on how to get it out? I'd appreciate it a lot. Thanks
Re: valve cover bolts?
So the bolt is stuck in the cylinder head? Nice! It's okay, it happens. Probably your best bet may be a set of drill bits that are specially designed for the romoval of the bolt. You can get these from craftsman at sears or other hardware stores. Follow the directions carefully (if they have directions) since you don't have too many shots at getting it out.Before you try to pull it out, you may want to spray something like liquid wrench onto the remains of the bolt to allow it to back out a little easier.
Here it is, about $12 at sears. This set comes in handy but you can also buy each size individually for about 2 to 3 dollars each if you wanted.
lol, yea im an idiot, i didn't realize i tightened it up that tight. okay so i need an extractor kit, thanks.
