Topic: 2.3 questions (Read 1061 times) previous topic - next topic
2.3 questions
Which volvo head fits the 2.3 I was thinking about putting a turbo 2.3 into a daily driver 65 mustang and replace the straight 6
'88 cougar 331 supercharged build in progress
'95 Blazer solid axle swapped 4X4- daily driver
2.3 questions
none, if i think what your asking is in relation to this http://msvorinich.itgo.com/October_23.html
 it requires major work
a shame as i wanted to do a NA motor someday but dont have the resources
2.3 questions
use the search function, this was discussed a week or two or three ago.  I think it was t3skidoo.  that's doing the swap.
2.3 questions
b234f is the DOHC people have used.
i dont see why "major work" should equal an answer of "none"
2.3 questions
Quote from: gumby;310900
because when ever i find a post related to the subject of swapping a volvo dohc head onto a ford 2.3 lots of them are under the impression its a bolt on affair, which it is not.
so the answer is then "none" are a bolt on, BUT can be made to fit with "major work".
and major work is hard to sum up when major to some is just changing a fuel pump.
see.
2.3 questions
supercharged88,
that sounds like a sweet plan.  I've wanted to do the same to a 67 fb (my favorite pony).
And not to be too pedantic, the head actually does bolt on.  You just have to plug some other holes .. and stuff.    :D
__________________
Twin '85 TCs
White/ Grey 2-tone
