Topic: Driver's Side Fender and Trim (Read 848 times) previous topic - next topic
I need a driver's side fender for my 87' Cougar, it must be a cornering lamp fender. I also need the trim for the driver's side from the back of the front fender to behind the door. I have the trim on the front of the fender with the corning lamp so I won't need that.
I have it from a thunderbird TC
since I am not all that far from you.. shipping should not be to bad.
You can always use a regular fender and cut the hole for the light too. (if need be)
Quote from: BogusSVO;311094
PM'd
Quote from: daminc;311096
Hopefully I can find a fender that has a place for the corning lamp. There is a big lack of these cars around this area, I've seen 2 total and never seen one in the s yard.
If all turns out well I may have found a fender (BogusSVO). If that's true I still need the trim for the drivers side.
I'm still looking for the fender and trim....
I have a black fender. Has a little surface rust but easily repaired.
Has lamp cut out also
$15+ shipping.
