Topic: Electroluminescet Emblems (Read 3127 times) previous topic - next topic
So, I'm trying to repair mine. Both inverters are good, they both whine when I put 12 volts across them. At first only one worked, but after messing with the other one (12 volts this way, 12 volts that way, what's under that label?) it works! So, I opened them up and desoldered the panels. Now, if I buy these
http://www.allelectronics.com/index.php?page=item&id=EL-5&extra=a%3A2%3A{i%3A0%3Bs%3A40%3A%2203823345592a403b2f4a37a59384e7ab28f02be1%22%3Bi%3A1%3Bs%3A0%3A%22%22%3B}
I know they'll glow green. But, can the panels be cut to size, and can they work with the stock inverters?
2002 Honda Civic EX
1984 Ford Thunderbird Elan
5.0 CFI, T5, Dual Exhaust
Eh, I ordered them anyway. I'll report back when they get here, hopefully with pics!
2002 Honda Civic EX
what part of Inverter did you over look:hick:
they put out AC only,,:D:D
the add clearly states  120vac or inverter input.  therefore the panels require an AC input so why are you putting 12vdc  across them?
maybe you just found your whine
Oh, no. I wasn't putting 12 volts across the panels, I was putting 12 volts across the inverter. So, to anyone wondering, you can cut the panels, but don't fold them and expect them to light up after the fold...sizzle sizzle crack....They glow blueish, not really green, and I think they look  nice.
So, behold!!!
That dead spot on the side is the terminals, unfortunately you can't fold them behind the panel to hide them, the original panel had the lead coming off the bottom.
One of my inverters died anyway, probably the same one I revived. I'm gonna try to build a circuit to deliver the same voltage/frequency. The inverters gave off 280 volts at 30KHz, they feel kinda like one of those shocking pens when you touch the terminals. Ask me how I know.
*Edit* That reminds me, the site I ordered from is excellent. They shipped the product out the day after the order and they arrived two days later, all the way from California and they gave me a tracking number as well.
2002 Honda Civic EX
WOW  pretty groovy man :D
Quote from: dragon574444;311681
I've been ordering from All Electronics Corp. for over a decade; to put it simply, they rock. I've never been let down by them.
Nice work on the lamps. I rebuilt one of the Cougar lamps with a small "wheat-grain" bulb about 12 years ago, but it had a hot spot of light in the center and never looked perfectly right. It looked good enough to use on the car, though.
:roxor:: The light color is nice!
I'm glad you guys like them. Maybe after I do a little more research and figure out how to rebuild an inverter, I'll offer to restore these emblems for you guys.
2002 Honda Civic EX
:iagree:
:rollin:
Great Work!
Cool, keep us posted. Both of mine are out and I only have one NOS replacement.
Looking for one more NOS unit...:hick:
tbirdregistry.com
26480
27373
Of course. I've been a bit busy, but I'll get to them soon. I can tell you the new inverter I'm building won't be nearly as pretty as the stock ones. Those were pretty small, at first I thought it was just a cap...
2002 Honda Civic EX
