Topic: help me! (Read 1251 times) previous topic - next topic
help me!
hi! I have a t-bird 84 'and the electric system that supplies the gas pump does not work .. and the pump is new
.. and I have no idea what to do I hope I can help and thanks in advance!
help me!
:bowdown: I need your help!
help me!
Inertia switch tripped? ;)
help me!
Fuel pump relay maybe?
help me!
Like the others said... check the inertia switch and relay. Here's a recent thread with a similar problem (lot's more threads out there too).
http://www.foxtbirdcougarforums.com/showthread.php?t=26893
And on Eric's site
http://www.coolcats.net/tech/troubleshooting/inertia.html
Save a horse, ride a Cougrrr!
1988 Mercury Cougar - 5.0HO, 3G, AOD w/shift kit, 4.10 gears in 8.8, Mass Air, CAI, Pypes X-pipe, Pypes 2 1/2" exhaust, Pypes Violator lers
1997 Ford Mustang GT - stock
2000 Ford Ranger 4X4 4.0 - stock
2001 Mercury Grand Marquis- stock
2008 Ford Escape 4X4 - stock
help me!
If not that, then a wire to the pump may be cut or corroded in one of the connectors somewhere.
help me!
guess I will be the first to give you the warm welcome ;)  Welcome to our place of great info, enjoy your stay :D check the things mentioned above the inertia switch should be inside the trunk left of the trunk latch behind the tail light panel.  theres a little white button on top push it and see it it clicks back in place.  also the fuel pump relay is located up under the package tray next to the passenger side trunk hinge.  have a good day :D
