Topic: Control Arms (Read 1427 times) previous topic - next topic
Control Arms
I have a set of CHE control arms for sale.
The uppers are the double adjustable with the poly bushings.
The lowers are the tubular control arms with fixed spring perches and the poly bushings.
I also have solid replacement bushings for the top differential bushings which originally had 3/4 inch mounting holes.  I had a local machine shop make some 1/2 inch to 3/4 inch adapter sleeves so that the stock mounting holes on the CHE arms can be used.
220 shipped for everything, OBO.
Doug
Blueprinted 306, Thumper ported Canfield 195's, TLSR Camshaft, custom motor mounts, Parker funnelweb, Pro Systems Carburetor, Tremec 3550 II, 4.30 gears, Moser Axles, Team Z custom suspension with upper relocation brackets and anti roll bar.  At the track I run M/T 26/10's on Weld Star rims.
Control Arms
The control arms have less than 500 miles on them.  The car suffered engine failure at the track less than 2 days after I installed the control arms.  I have had them in the car so that I could move it around for the past 1 1/2 years.  New combo is finished and I am ready to install a mini-tub so the stock suspension will not work for me.
Control Arms
You've got a PM.
Control Arms
how much for the uppers shipped to 19102?
Control Arms
Sale Pending
Control Arms
:DThanks Doug!
Control Arms
Sold
Thanks Fox T-Bird/Cougar Forums
Control Arms
dang.. i was too late. :(
Control Arms
Geez, you been away for a while, huh?
