Topic: hello, new guy (Read 6507 times) previous topic - next topic
hello, new guy
Quote from: nick302;313601
ok, sorry its been so long, finally got it here so i can work on it, and to my suprise, no codes...so im stumped
Do you get code 11's indicating everything is OK?
hello, new guy
no codes, no code 11, none, it just says "no codes stored" after i turn the ignition off...
hello, new guy
Welcome aboard. Enjoy the site.
2003 Marauder 300B
1996-97 Cobra wheel straight but weathered (For Sale)
84 TC manual shifter handle no  (For Sale)
BTW, I had a 1988 T-Bird Sport way back when. I found out that it was totalled shortly after trading it in. It still has the ignition switch recall to date.
Special thanx to EricCoolCats for showing me to this site.:bowdown:
hello, new guy
BTW, Are you near Pittsburgh?
2003 Marauder 300B
hello, new guy
Quote from: nick302;313641
No code 11 is not good. It would mean the program in the EEC is not running.
When you turn the key on without starting the car the fuel pump should run for 1 or 2 seconds. If it runs continuously, that's another indication the EEC's program is not running.
I'm guessing a code scan tool gave the "no codes stored" message.
Try the other methods of pulling codes.
Use "therangerstation" link that daminic posted
In the computer section, EECIV diagnostics.
hello, new guy
If you think it may be the eec, I have one from my '88 Sport I no longer use or need. If you want to borrow it to test, then pay shipping, and I'll send it to you. PM me if interested ;)
nop
i don't think i need it, i found my prob, im pushing 10-15PSI fuel pressure, im going to replace the pump and see if thats the prob :)
hello, new guy
Did you check the fuel pressure regulator?
hello, new guy
no, i have about 40psi @ the rail tho, i put a new exhaust on it, all the way back, put a coil on it, and now it will sit and idle all day but as soon as i give it gas, it dies out, i think its throttle position sensor, im trying that today. i also replaced the IAC motor, do those need to be reset on our foxbirds?
now what!?
i went to take it off the lift at work, its 4 arms on the side, with the bump underneath, now it wont even get up that hill...it drove in and it will start shaking and die, any other ideas, no new codes
hello, new guy
well i found something out, the gauge i was using rest at 10 and i only had 30psi! is that enuff to run it well or no?
hello, new guy
Are you checking it with the vac line on or off the regulator? It should be 39-40 psi with the vac line off the regulator @ idle.
hello, new guy
no,i am not, i was checking it with it on the aftermarket motorcraft check valve at the begging of the engine, so would that be part of my prolem then? thanx again, id love to see my tbird on the road here in a couple of days
hello, new guy
One ? I have, how old is the gas in the tank?
