Topic: Question about the tilt steering lever.... (Read 2193 times) previous topic - next topic
How do you change it?I've NEVER had one break,but yesterday,the black plastic part of it broke off.
Also,if someone has one in nice shape.Let me know.
I always thought they just unscrewed.. But I also never really looked at it. I have one from the parts bird you can have. hopefully it's an easy part to undo. (I have the entire column intact as an extra for my cars)
They're pretty tight the first time you take em off. I bought a nice billet one for mine.
Quote from: EricCoolCats;309160
It does unscrew. Just be careful. ;)
ok. why?
Quote from: EricCoolCats;309172
Because if you're not careful you can accidentally let forth demons from hell. :evilgrin:
Always remember... if that does happen, and they ask if you are a god... say "yes"!
Save a horse, ride a Cougrrr!
1988 Mercury Cougar - 5.0HO, 3G, AOD w/shift kit, 4.10 gears in 8.8, Mass Air, CAI, Pypes X-pipe, Pypes 2 1/2" exhaust, Pypes Violator lers
1997 Ford Mustang GT - stock
2000 Ford Ranger 4X4 4.0 - stock
2001 Mercury Grand Marquis- stock
2008 Ford Escape 4X4 - stock
Thanks guys.
Jerry,I'll take it !!!! Can they be unscrewed without scuffing them up?Either way,I'll take it.
You got it. It should be ok... I'll treat it like gold.. I was pretty confident that they just unscrewed.
Quote from: CougrrrFiveO;309188
Vinnine, mine did the same thing about a year ago. Take off the plastic trim around it and the tilt lever closer to where it screws in will have 2 flat spots to allow for a small wrench to get a grip and unscrew it.
Sweetness.I like easy stuff to fix.After everything else over the last two weeks,this will be a pleasure.I may install it twice just because it's so easy.
The tilt lever does unscrew. However it may be tight. It is best to take the column shroud off and get as close as possible to the base of the lever with a rag and a pair of vice grips. Do not of course put the vice grips on the plastic handle end. If you have problems finding a lever I am sure I can find one next time I go to Pull-A-Part.
Vinnie, I'll try to send it out on Saturday
Jerry,you're beautiful.....in a manly kind of non-gay way of course..LOL.
