Topic: Mustang strut tower brackets with polly bushings (Read 1421 times) previous topic - next topic
For sale is a set of energy suspension strut tower bushings with mounts for a mustang. The only thing you have to do is drill a new hole to mount them, this way you can use mustang struts like strange and other manufactures. I am no longer using them because I bought C.C. plates for my car, I will take $25. shipped. Also less then 1,000 miles on them
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
anyone?????
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
So if I were to buy these would I be able to run mustang struts on my 87 bird??
87 TC
yes, but you have to drill 1 new hole about 3/8 to 1/2" because the front one is a little closer then the birds. I had these on my 86' with Strange mustang struts, very simple install
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
bump
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
$20. shipped
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
sold pm me your info Thanks
87 TC
OK so after searching and reading for the strut options for the bird I need some help figuring out what struts to order for my 87 TC using these strut tower bushings I would like a little bit firmer ride and am planning on using all new polly control arm bushings with Mach springs. For the rear I am probably going to use a set of Chucks shock mounts and the KYB adjustable shocks. Any help would be appricaiated.
87 TC
I have the strange 10 way adj. (for the fox mustangs) and you can dial them in to what type of driving you do.
http://www.jegs.com/i/Strange+Engineering/873/S6001EM/10002/-1
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Will those work in my 87 TC using the mounts that I bought from you?
87 TC
I dont know if this will help or not but I recently did some research and as far as I can tell 87 and 88  tbirds use  Mustang struts
 The part numbers listed by Monroe , Gabriel, and KYB are the same for fox Mustangs and 87,88 birds 83-86 birds list different numbers
OK I think that NATO just answered my questions I think I will be going with a set of Strange adjustables for the front and the strange adjustables for the rear with chucks adapters.
87 TC
they should since both are fox bodies, but you might want to search for the correct info
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
