Topic: no oil pressure at high rpms (Read 2791 times) previous topic - next topic
Quote from: BogusSVO;308833
he may be pumping all the oil up on the heads, and the oil return holes are clogged with sludge and letting the oil pan run dry.... pop the VC off and se the oil returns clear ...
Quote from: daminc;308849
He does have a high volume pump that was put in last year.
Might be a combination of both of these 2 things together with the mileage that truck has. Just my .02
:burnout:
I went back and re-read the original post. I'd pull the intake off as well and clean the oil drain back holes there also.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
On Ford Modular motors, specs call for 6 quarts.  You can run more than this without issue.......Guys run 6 1/2 even 7 in some cases for the very reasons cited, especially the 4v guys.  Those motors like keeping oil up top and they have excellent flowback characteristics.....
Make sure it's at the absolute full mark on the dipstick and buy a GOOD oil filter for it.  I've tested some different ones personally.  A certain brand makes the warm idle pressure 4 PSI lower on my Cougar....It's a brand we all dislike here anyway....
an F-250 with a 5.0. with 250,000 miles.
It's not a mod motor. It's just a run-of-the-mill 302
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
I was citing the mod motors as an example.
May I ask which brand you're talking about?
FOXLESS!!
1994 Lincoln Mark VIII
FRAM huh???!!!
Wouldn't put one on a mower.
Correct answer stated above ;)
the only good thing about a fram filter is th "quick grip" so you can get it off your engine faster....
I personally think Wix or NAPA Gold are the best  common filter out on the market.
Motorcraft FTW:D
better yet,,, dont risk sludge falling in places you dont want it....
transition a shop vac to a piece of 1/4'' copper tubing.
vac the oil return holes out.
the 1/4'' tubing will go all the way to the crank or pan.
250,000 miles, I would think it may have issues. I'm sure at idle the pressure is not so good either. It's tired!!
Quote from: Kitz Kat;309334
It may be just that... I think we'll have some sort of clue or direction this weekend.
Motorcraft filters are made by Purolater, aren't they?
My dad has an '89 F-150 with the exact same problem. It's been parked for 4 years now, so I don't know the cause, but I'd suspect high miles have a lot to do with it. 5.0's ARE notorious for this, especially those particular years. And, there's a reason they say not to use a high-volume pump on a stock engine ;)
Hope ya get it nailed down painlessly :D
Stock replacement pumps are more than sufficient for most street engines (do some research on Dick Landy's engines).
Fram = FAIL
Motorcraft FTW
However my old 5 Star International sales rep saved us a ton of $$$ on a Cat 930 that smoked an engine.  The International Filters, FleetGuard offer a engine replacement guarantee if a engine goes tits due to an oil filter failure.  I run a Fleetguard on my 03 F-250
5.4L and have noticed no difference in oil pressure.
HMMM now that i think about it, the Motorcraft/Wix/Fleetguard filters all look the same....wonder who really makes em....
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
Fleetguard makes good filters.  My buddy uses them on his diesel F-series.
