Topic: 1.5 to 2.0 OD Band (Read 1387 times) previous topic - next topic
1.5 to 2.0 OD Band
Does anyone know if I can install a 2.0" Band where a 1.5" band was or do I need to swap the carrier it wraps around?
Backstory:
Pulled my SC trans to swap the OD band (started slipping).  I ordered the 2.0 thinking thats what should be in the car (Its should be an A servo).  When I opened it up, I pulled out a 1.5" band.  Looks like someone may have had a rebuilt unit installed at some point.
Thanks.
1.5 to 2.0 OD Band
I dunno about swapping but AFAIK the 2" was not installed in any Fox Bird/Coug AOD...
1.5 to 2.0 OD Band
This is for a 92 MN12 TBirdSC I'm trying to sell.  Just read that in 92 it was a  shoot if it came with the 2" or 1.5" bands.  Guess I lost that bet.  I think that you need to swap the reverse drum to the one from a 4R70W (and the accompanying planetary).
