Topic: I'm gonna sell my engine too...nuts! (Read 837 times) previous topic - next topic
Apparently a 5.0 is worth $200,000!
I'll have mine for sale soon, as well.
$200,000.00 5.0HO
They say Missouri is one of the worst areas for meth...after seeing this, I'm inclined to believe it all the more...:toilet:
Here's the text in case the ad expires.
So i am selling out a 5.0 HO i was going to put it as a custom project into a 2001 SE V6 mustang but realized the money cost factor of how much it was going to be to switch from OB1 to OB2 was going to be way to costly, plus the car would not be legal anymore. so i am sitting with a fully broke down cleaned and polished 5.0. I will say it now the the engine block cylinders will need to be bored and the heads P&P in order for engine to properly run right. It has been stored in proper conditions sheltered and in proper heated environment.The man who took the engine apart and put back together is a ASE certified trained auto technician so no worries on something not properly being done. The block is together right now and will in due time be taken apart.
parts for sale:
used cam shaft still in .00 run out 100 dollars
used crank that has been cleaned and balance to .01 (note max round out on these are .2) 200 dollars
heads are going for 75 dollars each
upper intake manifold 50 dollars
lower intake manifold 50 dollars
oil pan 20 dollars (will need to be repainted)
used working oil pump with neck included 60 dollars
harmonic balance 20 dollars
fuel injectors for all 8 properly working and showing good impedance 10 dollars a piece
aftermarket fuel rail 75 dollars
valve covers that have been cleaned and pained ford blue 40 a piece
ECU good and working from a 1988 5.0 HO 250 dollars
full uncut wiring harness for a 1988 5.0 HO FI 250
throttle body 50 dollars
used valve spring accessories 30 dollars
4 intake valves 30 dollars
4 exhaust valves 30 dollars
front cover 25 dollars
forged I beams with crank journal bearings 150 dollars
used IAC 20 dollars
used distributor with good working cap 75 dollars
used exhaust headers that have been cleaned and repainted 35 a piece
full FEL PRO gasket kit 100 dollars
fuel injector seals 3 dollars a piece
engine block with new main crank journals and cam shaft bearings 200 dollars(note the main saddles where straight bar measured and showed no wear in either main saddles or cam shaft journals)
complete sell which will include all listed: 1500 dollars
please note all parts are used but were tested to the max with proper equipment and cleaned properly as well
also please note you will also have to add on shipping to cost, but depending on how much is being bought we will talk down on paying for it ourselves if enough is sold.
I hope stupidity isn't hereditary...:hick:
It's obviously a typo.
It even says 1500 complete,which is still way high.
it's supposed to be a price range. $20-$1500 :facepalm:
1979 Ford Fairmont
[/B]
I thought maybe it was the mileage.
